SaaintJimmy
Member
New update! I absented for awhile because I had to get some other polycarbonate and the drawing you will see now had me really busy since I didn't know exactly how to do it in some spots. In the previous update I told you that I would've used aluminum over the red panel, but I rejected this idea right after I cut the first aluminum panel: due to the 0.5mm thickness, it was getting crumpled just looking at it and it would've been so difficult to work on it compared to the polycarbonate.
So, today we're seeing first cuts on the two top panels and the third layer/panel on the front that has to be bent on both sides and detailed with other pieces. I'm planning to get it done within tomorrow. The look will be fantastic once the red panel will be lit evenly!
Let me know that you guys think!
