Hello, Everyone!! Yet another guide.
The MSI D-Bracket 2, Explained.
The MSI D-Bracket is a small, well, bracket that fits in an empty PCI slot opening, that includes 2 USB Ports, and Four LED's, in this layout.
1 2
3 4
Here's A Key, To Decoding The LED Patterns!
If you are having trouble reading that, I also typed it out.
1 ALL RED
System Power ON
-The D-LED will hang here if the processor is damaged or not installed properly.
2 ALL RED EXCEPT TOP LEFT
Early Chipset Initialization
3 ALL RED EXCEPT TOP RIGHT
Memory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
4 BOTH BOTTOM RED
Decompressing BIOS image to RAM for fast booting
5 ALL RED EXCEPT BOTTOM LEFT
Initializing Keyboard Controller
6 TWO RIGHT RED
Testing VGA BIOS
- This will start writing VGA sign-on message to the screen
7 TOP LEFT & BOTTOM RIGHT RED
Processor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
8 BOTTOM RIGHT RED
Testing RTC (Real Time Clock)
9 ALL RED EXCEPT BOTTOM RIGHT
Initializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
10 TOP RIGHT & BOTTOM LEFT RED
BIOS Sign On
- This will start showing information about logo, processor brand name, etc...
11 TWO LEFT RED
Testing Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
12 BOTTOM LEFT RED
Assign Resources to all ISA
13 BOTH TOP RED
Initializing Hard Drive Controller
- This will initialize IDE drive and controller
14 TOP RIGHT RED
Initializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
15 TOP LEFT RED
Boot Attempt
- This will set low stack and boot via INT 19h
16 ALL GREEN
Operating System Booting
Most of the time, if the D-Bracket hangs at, "Early Chipset Initialiaztion," and will not change after numerous hardware configurations have been tried, your board has suffered from static electricity shock. You will need to RMA your board.
1 2
3 4
1 ALL RED
System Power ON
4 BOTH BOTTOM RED
6 TWO RIGHT RED
Testing VGA BIOS
8 BOTTOM RIGHT RED
BIOS Sign On
11 TWO LEFT RED
12 BOTTOM LEFT RED
13 BOTH TOP RED
14 TOP RIGHT RED
15 TOP LEFT RED
Boot Attempt
16 ALL GREEN
