Guide/How-To (No 56K): 1500W Immersion Load Tester
NoL
WARNING: This guide features crappy humor, meh photography, and volatile sealent. When working remember that airflow is your friend, so open a window. Also watch your fingers and if your younger, work with a parent or with their supervision, and lastly this isn't for everyone so work at your own risk.
A guide in pictures, but I'll add some wording as well. Decided today to build a immersion load tester, mostly for chillers, but surely can find other uses for a large inline load testing system. Can test a water loop or heat up a nice bath as well!
Total cost for the load tester was around $40. This of course is without a large variac, (20 amps recommended for this sorta load), to control the load, and a kill a watt to read the load.
So pictures;
Total parts about $40 as I said, but you can see just how simple. Theres some primer and such that I was going to use but decided to go with aquarium sealant, should hold decently I think.
All the PVC is 2 inch.
Very easy and acquirable tools.
The heater;
We start with the basic design, the main tube chamber contains the immersion heater, the in and outputs, and a Y off. The Y off will go to an open top for adding liquid as well as monitoring flow and dropping in a temperature probe if wanted.
Actual sizing now, of course with a 8" long immersion heater you dont need a 2 foot PVC tube ;)
Hacksaw cutting, really easy, I mean, seriously, very easy. The rule of thumb here is, thumbs don't grow back. Remember that.
A few ounces of elbow grease later;
A bit long, but on purpose, want some extra liquid in the bottom;
Broke out a 3/4" holesaw bit, could have used the adjustable, but couldnt find my hex driver. Easy as pie with PVC, didnt even need to clamp it down;
A little loose due to the bow of the tube, but more then good enough!
After setting the adjustable holesaw to a size I deemed "close", I drilled the pilot hole, trick here is to flip the end cap over;
Vrrrrrrrrr tada!
Now flip it back; :rolleyes:
Clamp or vice is really needed here, but the adjustable hole saw goes right thru. Watch your hands and body here as the spinning bar can break bones. :shocked:
Dropping in the immersion heater, bit tight it seemed then spinning it slightly went right in like it was meant to be. And after another 360 degrees perfect fit, nice and snug, and the rubber gasket makes a tight seal;
Sealent;
Begin the sealing! Murder on the hands indeed, but solved that shortly. Just pull back the tube a little bit, spread on the sealent, then slide it back. Then follow with a paper towel to remove excess and push it further into the joint;
Call it lazy, I call it innovation;
Now we're sealing tight!
And leave to dry!
Bit ghetto. Just the way it should be:D.
Nice job there dude. But 1500w? Bit strong ani't it?
Octo-SLI & 16core ready :p
Bit ghetto? Bah the best inventions are made from PVC. It serves every purpose. Hows it look ghetto? Needs to dry and then maybe some paint. Then again just some neat looking insulation and a painted table mount.
Looks very good. But I agree, 1500w seems a bit much, I assume thats 1500w max but you can run it lower?
Edit: sorry just saw this:
Ok, I`ll play the dummy here.
Is this something u can introduce to a wc loop, in place of your cpu/gpu, to emulate them/it being there ?
Effectively creating heat for the loop to cool so u can be sure the loop is working as desired b4 u actually put in ur setup ?
(... and not an elaborate bong >.< )
Its a load tester for chillers. It simulates the load of several components in a loop just pumping heat into it. It lets you test the loop with out the time, hassle and risk of plumming into a full PC.
Basicly yes, but a rad would have a hard time with a 1500w load.
Presumably this has very low flow restriction which might slightly affect the outcome. Of course you could stick the waterblocks in the loop too, purely for flow resistance. Or do you think this would be negligible?
was about to ask the same thing lol
Yeah you can as it's a heat source/load but you'll need to get the heatout put set correctly to what you would be putting out off the parts used
