guide: basic phase change
iloveamd64
Phase Change Basics
1. What is phase change?
Phasechange is a term used to describe what happens when refrigeration occurs. Lick your finger, and wave it around in the air. You are experiencing phase change. The spit on your finger evaporates as you wave it in the air, and as it evaporates, it sucks up heat along with it.
2. How does phase change work in a refrigeration system?
The compressor compresses the refrigerant into a high pressure... Where in the condenser, it condenses to a liquid under high pressure and also at the same time gives up its heat. It then travels to the liquid line, where liquid refrigerant usually travels through a filter/dryer, which filters out particles and is a desiccant, meaning it absorbs moisture. From that point, it travels to the metering device, usually either a capillary tube, or Thermal Expansion Valve (TXV). These regulate the flow of the liquid refrigerant, because at this point is under far too much pressure to evaporate. Once it leaves the metering device, it enters the evaporator, where the liquid refrigerant boils off, sucking up the heat with it. It then travels down the suction line of the system, back through the compressor, and into the condenser.
thanx to jimmydean a very good mate of mine for helping with this.......
EDIT: there will be more to come.....waiting for my mate to come up with the rest
name='harmonicgen007' said:
thats nice man but what does it have to do with computers
It has to do with Phase Change.. lol
Like what XMS is getting in replace of his water cooling, should get him over 5GHz :D
ahh yepp okk
if XMS gets it over 5ghz, that will make it the most powerful rig on SX i imagine lol
harmonicgen007 said:
ahh yepp okk
it already is running at 4.5ghz :) well i doubt it is atm cos he is on air cooling
go for it lol it would beat XMS's 5ghz that austin was telling me about :bootyshak
The current 3.6+ghz AMD's are fuckin whoopin' high oc'd Intels in the ass :bootyshak
