As most of you probably know, COD4 profiles are stored locally for some silly reason. That means any corruption, format or w/e will result in you having to restart...unless you backup.
To backup:
Backup the folder called "players" in your COD4 directory
C:\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\
Note: You have to use the same key (you would do normally surely?)
To restore in XP:
Simply plonk it back in the same place, ensuring the folder in players\profiles which should be your username, matches the text inside the active.txt else it will not work
In vista it is different...I have just learnt...
C:\Users\"USERNAME"\AppData\Local\VirtualStore\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\ would be its situation...do the same as above only at this location.
To backup in Vista just backup from the location above and restore using either method
Thanks
To backup:
To restore in XP:
Thanks
