maniac
So Guys,
First of all, yes I'm still alive, just been busy with life in general
So yesterday windows wouldn't boot up, it would load the windows logo and crash and restart and repeat. So I removed one of the cards and booted up normally.
Then the testing started, I ran a couple of runs of stone giant on the fitted card, temps, frames and textures where normal so I guessed it was the other cards fault. So I replaced the card and re-run all the tests and everything went normal.
Then I tried Sli again and it booted normally, but when I ran stone giants, from the loading screen I began to get red horizontal lines all across the screen. So I disabled sli and it ran normally again.
Then I hooked the monitor to the other gpu and started seeing artifacts in windows and movies. But it ran fine alone.
Anybody know what the issue is? maybe the cards had a fight and they dont want to work together anymore?
cheers,
maniac
cheers,
maniac
