GTX560 (570/580) hang problem with O/C'ing and F@H ?
SnW
EDIT found my old thread ...
http://forum.overclock3d.net/index.php?/topic/31662-fh-evga-ftw-and-overclocking/
Is this still a problem ?
I mean ones you have a Fermi card in PCI-E slot one you can't overclock any more ..or it will hard lock ?!
Looking at these or maybe 2x GTX570....(thinking real hard).
But i also noticed a new socket (2011) , man i need to start some reading again and FAST!
Greetings Ray..........
Going to mark this thread as solved,
al tho it IS solved by buying a GTX280 (i used to have a GTX260 in there) that will go into PCI-E slot 1....
if i find this Fermi locking problem, i'll post the link(s)..
Greetings Ray and Happy Folding....
http://forum.overclo...d-overclocking/
If you can find one or two gtx570,that would be your best option.They will produce 16k-17.5k ppd each,and the gtx560 is 14k-15k ppd.Dont know about gtx560 448core,but they have the same cost as gtx570.
Oo there different spec GTX560"s ?
darn it, i need to start reading more (hardware knowledge) and Fast !
BTW was there a PPD drop in regards to GPU Folding and NvidiA ?!
because i used to get that PPD with my GTX470s and GTX460s ....
Thanks for the heaqdsUp mate
