Ummm - i don't it quite works like that
when SLI-ing GPUs, they have to be the same brand/model
They dont actually, they just have to be the same GPU. I am not saying the 590 will work with a 580 but if you take a normal Asus 580 and an EVGA 580 they will run in SLI.
You can't sli a 580 with a 590. Unlike how you can crossfire a 5970 with a 5870 or a 6990 and 6970 for instance.
i would have said manufacturer otherwise![]()
Really? Cool. So you could run tri-fire with a 6990 and 6970. [/size] Can you crossfire any of the 6xxx together? Where did you find this out btw? I know ATI use to have a chart that showed all the cards you could crossfire together but haven't seen a updated version in ages.
But since 590 is running 2x 580 GPU's i just thought maybe it could work :lol:EDIT: What is "Lucid Hydra"??
Reading a review the other day, apparently you can SLI 590 + 580 but nvidia just havent enabled it within there drivers, appaerntly so anyway.![]()
