GTS 450
Tomtom565
Hiya,
Just been looking over my next build list...... and was wondering whether to get another 450, or upgrade to a 570 or somthing like that, not a big fan of the red side of the sea........ (if you know what i mean
) , and just wanted to know your opinions.......
if you wanted to know my build list is as follows....
I7-2600K
,Gigabyte GA-Z68XP-UD4,Kingston HyperX Grey Dual Channel Kit 8GB (2x4GB) DDR3 1600mhz x2,Bitfenix Shinobi with window
,OCZ Technology 60GB Vertex 3 SSD,1TB Seagate Barracuda x 2 ,Corsair HX 850W,Be Quiet Dark Rock PRO
cheers in advance...
Would upgrade it. For the prize of one 570, you could get x2 560 or x2 560Ti(maybe a bit more expensive, depending on your prizes). Check out benchamrks for 560/560Ti sli, and you will see they beat alot more expencive cards.
mmmmmmm.........looking at it, it does look like and alternative ( a bloody good one at that!), anything is better than my system mind........ what does everybody else think? Or what about the 550's?
mmmmm.......i thought they fixed the micro stuttering???, seems like a hard desicion, what single card would you recomend? think i might just hold out and see how much money have left over....and my job doesnt exactly create amazing income.....
, and terrifictez, how much are you selling that 450, could just use it as a dedicated physx card....
echoing what other i are saying i would say upgrade, another 450 migh be cheaper but your not gonna get the "graphical mileage" you would from say a 570 (which i know is more but will give you more from it in long term)
I would say look at a 570 they are cracking card and they are the graphical sweetspot for gaming. A 560Ti is still a very good card if funds are tight (they oveclock like crazy). lollipop has a 560Ti and he seems ok running BF3
Opinion = single card.
.... although part of me is wanting you to get a 450, clock the crap out of it/them, and post results
If you're looking at a 850W PSU, I think it would be great to go for a GTX 580. Something like the Gigabyte SOC GTX 580 would be a great upgrade, but the regular GTX 580 is also very nice.
