I get 4.5 @ 1.285 stable in Prime 95 for 4+ hours. In order to run 4.6 in P95, I have to up the voltage to 1.350. At 4.7, I've only been able to get it stable in P95 at 1.405 volts. Yeah, the voltages are high, but it's what I have to run to get them stable.
At the 4.7 clocks, temps are topping out in P95 at 76c.
At 4.6, topping out at 68c.
At 4.5, they're topping out at 64c.
I've only really messed with the multiplier and the CPU voltage, so if there's anything else I can do to bring those voltages down, so I can get a bit more out of it, I'm all ears. I haven't been able to get 4.8 stable using just these two settings. But....they're the only ones I really understand, so they're the only ones I'm not nervous about messing with. I've heard people talking about lowering the CPU volts, and raising PLL voltage, but....I'm not really sure what that does.
System Specs:
i7-3770k
EVGA GTX 670ftw 2GB
16GB GSkill Sniper 2400
ASUS Maximus V Formula
Ultra X4 1050 watt PSU
XSPC Raystorm CPU block
XSPC Raystorm GPU block
XSPC 120.2
XSPC 120.3 crossflow
Dual D5 pumps, with bitspower mod top and 250mm res
Fractal Design Define XL r2, heavily modified
