arnzzz
Ive had a bit of an obsession for thermal paste for a few weeks now
it all started when i got my Noctua NHD14.
Originally when i got the noctua i had a cheap HD6670 gpu installed, but seeing as the noctua had some TIM which
came with it i thought "its gotta be better than the stock TIM on the 6670" and i had heard good things about the noctua
stuff, so i went ahead and changed it. All was fine until i went to put the heatsink back on and just the design of the heat
sink and the way you have to place it on the board while holding it still and doing up the screw's at the same time made
the whole thing a little awkward. I say that as i always felt after fitting the heatsink that the whole thing had moved, swivelled
and shifted from side to side way to much for my liking that the TIM must have gone everywhere but where i wanted it. I
ended up redoing it about 3 times before i just made do. As im writing this im thinking maybe i should do it again, but as
im not using the 6670 now i wont bother
So today i decided to do the HD6950 i am using now, yes there was no need to do it, but i wanted to do it
The whole thing was so much easier with this card just because of the way the heatsink was designed, on the picture
below you can see the 4 little bar's (don't know what the official term is
) on the heatsink that poke through the PCB
ready for the screws to hold the card together, Those are like a perfect guide holding everything just where they
need to be
The one thing i did notice which you cant really see from the picture is the copper surface of the Heatsink was a
really bad finish compared to that of the noctua, you really could feel where it had been machined, i honestly feel
like i could do a better job with some fine wet n dry paper. I won't though....Honest
So all round very happy wth my TIM change.
knocked off 3 degrees too
need to be
