GPU boost clock and fan speed on a GTX Titan
WebMaximus
I have a first generation Asus GTX Titan and have a couple of guestions.
First I tried this weekend to do some overclocking by downloading Asus GPU Tweak (GPUTweakVer2820_20150318) and after playing around with the tool a bit I decided to go back to the default settings but for some reason it seems that the boost clock value got stuck @ 1006 MHz and I can't get it back to the default (876 MHz) even after pressing the Default button in the GPU tweak tool followed by pressing the Apply button.
Is there anyway I can do some kind of 'factory reset' of my Titan card to force it back to it's default clock speeds?
Here's a picture what it looks like in Nvidia Inspector
Then I have a question about the fan speed. I noticed how the fan speed won't go above 55-60% even when the GPU is under full load and the temp reaches 80C. Are there any good tools/utils I could use to define the fan speed settings myself where I for instance could say that when the temp goes above 70C I want the fan speed to increase to max? I tried the user defined fan speed setting in Asus GPU Tweak but couldn't get it to work since I wasn't able to move any dots in the diagram in the way I've seen others doing on YouTube.
Many thanks in advance for any input both on the boost clock speed issue as well as how to set the fan speed thresholds manually so you can decide the fan speed depending on the temp yourself.
