Gpu 210mm including 6 pins?
Rob_the_scot
randomly looking has any one know gpus that are 210mm including if I had say 6 pin hooked to the bottom of the gpu
I know a few gtx 750/tis will fit
Amd 260x
MSI has some cards that are intended for Mini-ITX systems, I think they have an R9 270X and I think a GTX760, both of which are 170mm long (i.e. they fit exactly the dimension of an ITX mobo). Have a look at those, they're quite a bit faster than the 750/260.
I shall have a look, cheers...dont need to powerfull card
Mine as well get the best you can afford. No sense is spending less to needing more down the road. Just the price/performance is better when you use a card for a long time.
