ZenModz
Gears of War 4 - ZenModz
Hello again every one!
I'm back again with a new build
I think the title pretty much says it all.
I had planed something else for the this next build but things changed in the build plan, so the build has changed a bit to suit. I had planed a build with lots of RGB lighting but that build will come later.
But for now Gears of War is in the works, Hope you all enjoy the ride.
anyway I will get straight into it with some build photos as I know that's what you are all here to see
sexy pic's and mooding.
To start of I will be using a new Cooler Master, Master Case Maker 5.
The Case comes with a tin box with all the screws and other bits and two other parts that I will need to look into.
The box also has soft rubber back on it that is also magnetic. witch I think is a nice touch.
The case also comes with a Red led magnetic strip.
That archers to the ran controller that's fitted to the back of the Mo-Bo tray.
Now for some hardware info:
Mobo: R.........................?
No I don't think I'm going to say just yet.
Still so much more to show.
The build will have 2 of the Masteraccessory Tempered glass sided panels
More again, Tomorrow with many many more photos and more info on the build.
Thanks again for stopping by.
