Good quality m-atx sk939
deathwish
i am looking for a good quality m-atx board sk 939,ddr,pci-e
want something that will overclock well and that will last untill i go onto am2
any sugestions?
The best mATX AMD boards are most definitely the Biostar Tforce6100 boards. Unfortunately they are kinda in short supply. If you can find one though...
Given that you get the right board (the non-SE version). The A8V-VM is quite solid. Good featureset for the price. Altho its only a medicore clocker at best.
The two PP suggested would be better, but will prove a right PITA to obtain in the UK.
I havent personaly worked with any of these boards but they where just what others suggested to me when i wanted to make a toaster. Back in those days though i wanted AGP instead so i was SOL. THat board looks decent. Hope you didnt want Gigabit though :/
naa those are fine planing to build my pc into a silverstone sugo as it would be easyer to transport to lans and to my brothers uni when i visit
Thats the same reason i wanted to make myself a toaster. Tired of lugging this steel case around and i frequent LANs alot.
Thing is air also needs a way to get in...
I have the Asus and really dont like it, the Biostar Tforce6100 (that WC recommended) is a million times better.
