Good overcloak MSI 570 TF3
Dr.House
Hey
I want to know what is a safe overcloak for my card it currently running at Core 900 Memory 2400 and shader 1800 But in MSI afterburner i cant increase the voltage?
Hey
What temps are you getting. Also is your card a GTX570 Power Edition?
What's an overcloak?
This one looks good I think....
Why wont msi utility let me raise my Voltage ? any1 its locked and i have changed the setting to allow me to?
you will need to go to the MSI website and download afterburner beta (i think its version 7) once you got it up and running you will need to got settings and check the box that say "unlock voltage control" you should then be able to the adjust the volts. 900Hz with no voltage added is pretty good. what test have you been running and at what settings?
