good cooling set up for the following parts ..
mayhem
Wondering what a good cooling set up would be for the following parts
Asus p5k permium
q6600
Geforce 8800 GTX
8600 GT 256Mb
running 4 1tb samsung F1's do they need cooling.
Would it be good to go for 2 loops or 1. Can the 8600GT be water cooled if so what with.
Would a double rad do the job or would i be better off with triple.
Size makes no difference on this build as its going into a custom cab.
price wise im not looking to spend more than £150 to £200
any advice would be help full as i haven't water cooled for about 1 to 2 years now. so im a bit out of date with what's good and what's pants ....
Pointless cooling the 8600GT tbh if its Physx only, not many games use it so it won't be loaded much? and it won't run too hot anyway, perhaps a better or a passive heatsink for it?
The GTS, will be a 512MB as Zotac didn't produce any G80 GTS' iirc. So a waterblock on that and the CPU, on a triple rad with some good fans should be fine and not push your budget too much, and allow you get a possible aftermarket nb cooler if you feel the need
Ive got an 8800gts 512 block here FS actualy, if you give me a hoot mate I might be able to sort you out a full system.
yeh its all for show but will need to be quiet. the 8660 is just physx only based. Its all so used as well for a Touch scean system that i use so it is not hammed.
This will be the set up im going to stick inside my project (hopefully saving some money on hardware)
I can fit any size rad in it and space is not a problem as i have loads to play with.
I would like to cool all sections of the Motherboard if possible and keep noise down to a minimum noise. The system will be slightly over clocked but not to much as there is no call for it and stability is a must.
Tom yeh if you send me a price i can pass in onto my lass and she will let me now if its a goer .. that would be grate thks.
