paulstung
I have run into a problem with my new build, I went about the usual way of testing on the box it came in, but it wont boot, all I'm getting is the cpu fan spins for a second then stops, then spins then stops, and it goes on and on. I have tried a speaker, and that seems to make like a low click sound as if it is trying to beep.
I've tried 1 stick of ram, in each slot, both sticks in each slot, and the same again with different sticks. I've checked and double checked all connections, and unplugged everything not needed. The CMOS has been re set, and the CPU has been re seated, and pins checked, and I've done all these steps with 3 different power supplies. But nowt, the same result.
I'm running a Intel G3528, with a Gigabyte Z87 D3H, with the stock cooler, and no GPU, just the basic board cpu, and cooler.
Any ideas guys ? From what I've tried I'm stuck, all I can think of is dead board, so RMA time, I've only just received it so no problem there.
