Hi there.
I know my system specs are outdated but i would appreciate a bit of help in order to find out where i am making the mistake with my overclocking.
Goal is to achieve: 4GHz fully stable (Even 3.8GHz wouldnt hurt so as to enjoy latest titles such as crysis 3 , dead space 3).
System Specs:
Gigabyte x58 ud7 Rev 1.0 (F9a Bios)
i7 930 D0 2.8GHz CPU
Corsair Dominator 2000MHz Tripple Channel ddr3 Memory -8-8-8-24
Evga gtx480 GPU
Enermax Revolutoin 1250W PSU
SB Xfi titanium fatality pro sound card
Samsung 840 PRO SSD AHCI Mode - Win 7x64 SP1 Enterprise
Prolimatech Megashadow Push Pull config.
Bios Template:
Advanced CPU Features:
CPU Clock Ratio ................................ [21x]
Intel(R) Turbo Boost Tech .................. [Disabled]
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [Disabled]
C3/C6/C7 State Support .................... [Disabled]
CPU Thermal Monitor ......................... [Enabled]
CPU EIST Function ............................ [Disabled]
Virtualization Technology ................... [Enabled]
Bi-Directional PROCHOT ..................... [Enabled]
Uncore & QPI Features:
QPI Link Speed .............................. (36)
Uncore Frequency .......................... (16)
Isonchronous Frequency ..................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) .................... 200
PCI Express Frequency (MHz) ........... [100]
C.I.A.2 [Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[800mV]
PCI Express Clock Drive ................... [900mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Advanced DRAM Features:
Performance Enhance ...................... [standard]
Extreme Memory Profile (X.M.P) ......... [Disabled]
System Memory Multiplier (SPD) ........ [6]
DRAM Timing Selectable (SPD) .......... [auto]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................7
tRCD .......................................7
tRP .........................................7
tRAS .......................................20
Command Rate CMD..................1
CPU
Load Line Calibration ................. [Lv2]
CPU Vcore ...............................1.375
QPI/VTT Voltage 1.150v ............1.355
CPU PLL 1.800v .......................1.900v
MCH/ICH
PCIE 1.500v ...........................1.560v
QPI PLL 1.100v .......................1.220v
IOH Core 1.100v ..................... 1.140v
ICH I/O 1.500v .......................1.560v
ICH Core 1.1v ........................1.140v
DRAM
DRAM Voltage 1.500v ..............1.66v
DRAM Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
I have set the memory multiplier to 6.0 to check what stability i can achieve with memory at 1200MHz @ 7-7-7-20 and 1.66v.
Linx pack it will crash at around 150-200Times.
Unigine Heaven 3.0 at max settings will crash on the 4th run.
Conclusion Crysis3 , Deadspace3 etc will crash after 15mins approx of gaming.
Any thoughts ?
I'd appreciate you help.
Thanks all!
System Specs:
Evga gtx480 GPU
Bios Template:
C.I.A.2 [Disabled]
Channel A + B + C
CPU
MCH/ICH
DRAM
Any thoughts ?
Thanks all!
