Gigabyte Radeon 6950
Best thing to do is email EK. The main thing to note is there are different pcb cards so you have to make sure yours are reference first....
6970 and 6950 do have very similar pcb's though and some brands make blocks that fit both cards.
Check out coolingconfigurator on EK website !
Are your cards reference models or custom PCB's ???
Which Gigabyte models do you own ?
I had two MSI 6950's 2Gb reference cards and the EK FC 6970 fitted like gloves on them !
Cheers Bro !
Yeah its the windforce from gigabyte , and i think they dont make blocks for them because your coolers is only attached to the card by the four holes around the GPU , the V2 block has 10 mounting holes that might be the reason !
It might be phisically possible , but the weight of the waterblock isnt equally spreaded over the entire card , will not make proper contact on the vram and vrm's and may dammage your PCB .
Perhaps i could be wrong , so wait a bit for more advise from the community !
