Gigabyte gtx480 soc
Something like 1k ppd less than a gtx580,and its recommended to have 40A available just for the gtx480 soc.Something like 430w powerdraw i think.
But it would replace my to asus gtx460 or the asus gtx560,they are annoyingly loud compared to my gigabyte gtx4xx gpu`s.
Nah, no single GPU available today running at its original factory speed (even the Gigabyte SOCs) will be guzzling 430W on their own. My rig when I had my old 570 (must update my sig!) when at 850/1000 and my CPU at 4.7 never went over 330W (100% load on both, though I found it was actually lower when F@H), and I do not believe that any factory-speed 480, which is fundamentally extremely similar to a 570, will take that much extra juice.
Wanted that gtx480 soc really bad,but had to think right also.
With a sparre r3e from a rma,i found an i7-970,1 month old for the same price 250£ with original receipt
Turned up to be a good deal.Was linx stable at 4.4ghz @ 1.325v
,but it was a little too hot,like 78-81c
Now folding at 4.2ghz @ 1.285v,max 65c .Need to save some money now to get that cpu under water now
Awesome! I'm thinking at that speed you could probably pull at least 80k+ ppd from it if you ran it in a Linux VM (native is even better) using the bigbeta flag.
One rig is running ubuntu with bigbeta flag,but it only get like 3-4 bigbeta wu`s a month.Normal big wu`s has a tpf at 20min spot on.
When i get the new cpu under water,i will have it folding in linux.
