GIGABYTE GTX 570 GV-N570OC-13I
neoguyver1
My max overclock of 900Mhz core @ 1.088v from a stock speed of 780Mhz not sure is it safe to push further. I used NVIDIA Inspector 1.9.5.5 to push the voltage up a little.
Made 3 handy taskbar icons 780/860/900. Nvidia Inspector allows you to create overclock shortcuts i then found a gigabyte .png and converted to .ico and adjusted colours yellow/orange/red.
Some of my results
3DMARK '06
25785 3DMarks
http://3dmark.com/3dm06/15932183
3DMARK '11
P5370 3DMarks
http://3dmark.com/3dm11/1612308
3MARK VANTAGE would not finish with 900 do i wound back to 860mhz and got ...
3DMARK VANTAGE
P24352 3DMarks
Hope to push it as far as I can but would like to know how you got on with your GTX570 and how high could you push and what did you use?
