neoguyver1
GIGABYTE GTX 570 GV-N570OC-13I
My max overclock of 900Mhz core @ 1.088v from a stock speed of 780Mhz not sure is it safe to push further. I used NVIDIA Inspector 1.9.5.5 to push the voltage up a little.
Made 3 handy taskbar icons. Nvidia Inspector allows you to create overclock shortcuts i then found a gigabyte .png and converted to .ico and adjusted colours
yellow/orange/red.
780 / 860 /900
Some of my results
3DMARK '06
25785 3DMarks
http://3dmark.com/3dm06/15932183
3DMARK '11
P5370 3DMarks
http://3dmark.com/3dm11/1612308
3MARK VANTAGE would not finish with 900 do i wound back to 860mhz and got ...
3DMARK VANTAGE
P24352 3DMarks
Unigine @ 860mhz
COMPARISION To a 6970 I had
I hope to push it as far as I can but would like to know how you got on with your GTX570 and how high could you push and what did you use? How do guys get such high 3DMark scores?
Also how far should I push memory?
yellow/orange/red.
780 / 860 /900
Some of my results
3DMARK '06
25785 3DMarks
3DMARK '11
P5370 3DMarks
3DMARK VANTAGE
P24352 3DMarks
Unigine @ 860mhz
