Gigabyte Aorus DDR5 Taken to Over 9000!
Any videos out there showing how to work these new options that have been intergrated in the Agesa?
I currently run Buildzoids Eazy 6000mhz settings on my GSkill Z5 7600 Kit and wouldnt know where to start to get 7000+++
All my settings are below on latest 1515 Bios with Agesa 1.0.0.7b on Crosshair Gene X670E:
Code:
[2023/07/21 02:35:51]
Ai Overclock Tuner [DOCP I]
DOCP [DDR5-7600 36-46-46-121-1.40V-1.40V]
eCLK Mode [Auto]
BCLK1 Frequency [100.0000]
Memory Frequency [DDR5-6000MHz]
FCLK Frequency [Auto]
Core Performance Boost [Auto]
Tcl [36]
Trcd [46]
Trp [46]
Tras [30]
Trc [68]
Twr [48]
Refresh Interval [50000]
Trfc1 [500]
Trfc2 [400]
Trfcsb [300]
Trtp [12]
TrrdL [8]
TrrdS [4]
Tfaw [20]
TwtrL [16]
TwtrS [6]
TrdrdScl [4]
TrdrdSc [1]
TrdrdSd [Auto]
Trdrddd [Auto]
TwrwrScl [4]
TwrwrSc [1]
TwrwrSd [Auto]
TwrwrDd [Auto]
Twrrd [2]
Trdwr [16]
IBUF_LPWR_MODE [Auto]
ADDR_CMD_MODE [Auto]
M_ORDERING [Auto]
S_COL_WIDTH [Auto]
MC_SVA_TRIM0 [Auto]
MC_SVA_TRIM1 [Auto]
MC_SVA_TRIM2 [Auto]
Proc CA Drive Strength [Auto]
Proc Data Drive Strength [Auto]
CPU On-Die Termination [Auto]
DRAM Data Drive Strength [Auto]
Rtt Nom Wr [Auto]
Rtt Nom Rd [Auto]
Rtt Wr [Auto]
Rtt Park [Auto]
Rtt Park Dqs [Auto]
Power Down Enable [Auto]
Memory Context Restore [Auto]
UCLK DIV1 MODE [Auto]
Bank Swap Mode [Auto]
Mem Over Clock Fail Count [Auto]
Medium Load Boostit [Auto]
Precision Boost Overdrive [Auto]
Precision Boost Overdrive Scalar [Auto]
CPU Boost Clock Override [Auto]
Per-Core Boost Clock Limit [Auto]
Platform Thermal Throttle Limit [Auto]
Curve Optimizer [Auto]
VRM Initialization Check [Enabled]
CPU Load-line Calibration [Auto]
Segment2 Loadline [Auto]
CPU Current Capability [Auto]
CPU Current Reporting Scale [Auto]
Core Voltage Suspension [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Auto]
VDDSOC Current Capability [Auto]
VDDSOC Current Reporting Scale [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Power Phase Control [Auto]
DRAM Current Capability [Auto]
DRAM Switching Frequency [Auto]
DRAM Power Phase Control [Extreme]
MISC Switching Frequency [Auto]
Performance Bias [Auto]
Clock Spread Spectrum [Auto]
Runtime BCLK OC [Auto]
BCLK1 Amplitude [Auto]
BCLK1 Slew Rate [Auto]
1.8V PLL Voltage [Auto]
1.8V Standby Voltage [Auto]
Misc_ALW [Auto]
Chipset0 VDD Voltage [Auto]
Chipset1 VDD Voltage [Auto]
CPU 3.3V [Auto]
DDR_testA [Auto]
DDR_testB [Auto]
SMU_Comp1 [Auto]
SMU_Comp2 [Auto]
SMU_Comp3 [Auto]
R1 [Auto]
R2 [Auto]
R3 [Auto]
Sense MI Skew 1 [Auto]
Sense MI Skew 2 [Auto]
Sense MI Skew 3 [Auto]
Sense MI Skew 4 [Auto]
Raise RComp [Auto]
Dummy VOutA [Auto]
Dummy VOutB [Auto]
Algorithm 1 [Auto]
Algorithm 2 [Auto]
Algorithm 3 [Auto]
CCD Priority Memory Activity Threshold [1070]
CCD Priority Hysteresis [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
CPU SOC Voltage [Manual Mode]
- VDDSOC Voltage Override [1.25000]
CPU VDDIO / MC Voltage [Manual Mode]
- VDDIO Override [1.35330]
Misc Voltage [Auto]
VDDP Voltage [Auto]
High DRAM Voltage Mode [Auto]
DRAM VDD Voltage [1.35000]
DRAM VDDQ Voltage [1.35000]
PMIC Force Continuous Current Mode [Auto]
PMIC Voltages [Sync All PMICs]
SPD HUB VLDO (1.8V) [Auto]
SPD HUB VDDIO (1.0V) [Auto]
Memory VDD Voltage [1.35000]
Memory VDDQ Voltage [1.35000]
Memory VPP Voltage [Auto]
Memory Voltage Switching Frequency [Auto]
Memory Current Capability [Auto]
Security Device Support [Enable]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Firmware TPM switch [Enable Firmware TPM]
Erase fTPM NV for factory reset [Enabled]
Password protection of Runtime Variables [Enable]
PSS Support [Enabled]
NX Mode [Enabled]
SVM Mode [Enabled]
Resize BAR Support [Enabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
USB Mass Storage Driver Support [Enabled]
USB3.0 FLASH DRIVE PMAP [Auto]
TOSHIBA THNSFJ256GCSU 0 [Auto]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G2X2_C6 [Enabled]
USB_P8 [Enabled]
USB_P9 [Enabled]
U32G1_10 [Enabled]
U32G1_11 [Enabled]
USB16 [Enabled]
USB17 [Enabled]
U32G2_C18 [Enabled]
LAN_U32G2_19 [Enabled]
U32G2_20 [Enabled]
U32G2_21 [Enabled]
KBMS_USB22 [Enabled]
KBMS_USB23 [Enabled]
Network Stack [Disabled]
Device [N/A]
SATA Controller(s) [Disabled]
NVMe RAID mode [Disabled]
SMART Self Test [Enabled]
Restore AC Power Loss [Power Off]
ErP Ready [Disabled]
Max Power Saving [Disabled]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
CPU PCIE ASPM Mode Control [Auto]
PCIEX16_1 Bandwidth Bifurcation Configuration [Auto Mode]
USB Audio Controller [Disabled]
Wi-Fi Controller [Enabled]
Bluetooth Controller [Enabled]
When system is in working state [All On]
Q-Code LED Function [Disabled]
When system is in sleep, hibernate or soft off states [All On]
Intel LAN Controller [Disabled]
USB power delivery in Soft Off state (S5) [Enabled]
U32G2_C18 Type C Power Mode [Auto]
Alteration Mode Switch [PCIE Link Speed]
PCIEX16 Link Mode [Auto]
M.2 Link Mode [Auto]
Chipset_1 Link Mode [Auto]
GEN-Z.2_1 Link Mode [Auto]
GEN-Z.2_2 Link Mode [Auto]
Chipset_2 Link Mode [Auto]
PCIEX1 Link Mode [Auto]
Primary Video Device [PCIE Video]
Integrated Graphics [Disabled]
Global C-state Control [Auto]
IOMMU [Auto]
ECC [Auto]
SMT Control [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
L1 Stride Prefetcher [Auto]
L1 Region Prefetcher [Auto]
L2 Up/Down Prefetcher [Auto]
Core Watchdog Timer Enable [Disabled]
Platform First Error Handling [Auto]
Opcache Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
MCA error thresh enable [Auto]
SMU and PSP Debug Mode [Auto]
PPIN Opt-in [Auto]
Enhanced REP MOVSB/STOSB [Enabled]
REP-MOV/STOS Streaming [Enabled]
Xtrig7 Workaround [Auto]
SNP Memory (RMP Table) Coverage [Auto]
SMEE [Auto]
Action on BIST Failure [Auto]
PAUSE Delay [Auto]
Power Supply Idle Control [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
DRAM map inversion [Auto]
Location of private memory regions [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
Disable DF to external downstream IP Sync Flood Propagation [Auto]
Disable DF sync flood propagation [Auto]
Freeze DF module queues on error [Auto]
DF Cstates [Auto]
PSP error injection support [False]
Active Memory Timing Settings [Auto]
Processor CK drive strengths [Auto]
Processor CA drive strengths [Auto]
Processor CS drive strengths [Auto]
Dram ODT impedance RTT_NOM_WR [Auto]
Dram ODT impedance RTT_NOM_RD [Auto]
Dram ODT impedance RTT_WR [Auto]
Dram ODT impedance RTT_PARK [Auto]
Dram ODT impedance DQS_RTT_PARK [Auto]
Processor ODT impedance [Auto]
Processor DQ drive strengths [Auto]
Dram DQ drive strengths [Auto]
Disable Memory Error Injection [Auto]
TSME [Auto]
Data Scramble [Auto]
Chipselect Interleaving [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Subchannel [Auto]
BankSwapMode [Auto]
DFE Read Training [Auto]
DRAM PDA Enumerate ID Programming Mode [Auto]
TX DFE Taps [Auto]
PPT Control [Auto]
DDR Training Runtime Reduction [Auto]
Rx Burst Length [Auto]
Tx Burst Length [Auto]
RX2D_TrainOpt [Auto]
TX2D_TrainOpt [Auto]
RX DFE Taps [Auto]
MBIST Enable [Auto]
OC Recovery Fail Count [1]
PCIe ARI Support [Auto]
PCIe All Port ECRC [Auto]
Advanced Error Reporting (AER) [Auto]
PCIe ARI Enumeration [Auto]
PSPP Policy [Auto]
UMA Version [Auto]
GPU Host Translation Cache [Auto]
NB Azalia [Auto]
Audio IOs [Auto]
PCIe loopback Mode [Auto]
Persistence mode for legacy endpoints [Auto]
Retimer margining support [Auto]
CPPC Dynamic Preferred Cores [Auto]
ECO Mode [Disable]
TDP Control [Auto]
PPT Control [Auto]
Thermal Control [Auto]
TDC Control [Auto]
EDC Control [Auto]
PROCHOT Control [Auto]
Fan Control [Auto]
VDDP Voltage Control [Auto]
Infinity Fabric Frequency and Dividers [Auto]
FEATURE FCLK DPM [Auto]
SyncFifo Mode Override [Auto]
GFXOFF [Auto]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset 1 Temperature [Monitor]
Chipset 2 Temperature [Monitor]
T_Sensor Temperature [Monitor]
DIMM A Temperature [Monitor]
DIMM B Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan Speed [Monitor]
AIO Pump Speed [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
CPU VDDIO / MC Voltage [Monitor]
HYDRANODE Fan Association [Enabled]
CPU Fan Q-Fan Control [Auto Detect]
CPU Fan Profile [Manual]
CPU Fan Q-Fan Source [CPU]
CPU Fan Step Up [Level 0]
CPU Fan Step Down [Level 0]
CPU Fan Speed Low Limit [200 RPM]
CPU Fan Point4 Temperature [70]
CPU Fan Point4 Duty Cycle (%) [50]
CPU Fan Point3 Temperature [65]
CPU Fan Point3 Duty Cycle (%) [50]
CPU Fan Point2 Temperature [50]
CPU Fan Point2 Duty Cycle (%) [40]
CPU Fan Point1 Temperature [50]
CPU Fan Point1 Duty Cycle (%) [14]
Chassis Fan Q-Fan Control [Auto Detect]
Chassis Fan Profile [Manual]
Chassis Fan Q-Fan Source [CPU]
Chassis Fan Step Up [Level 0]
Chassis Fan Step Down [Level 0]
Chassis Fan Speed Low Limit [200 RPM]
Chassis Fan Point4 Temperature [70]
Chassis Fan Point4 Duty Cycle (%) [100]
Chassis Fan Point3 Temperature [65]
Chassis Fan Point3 Duty Cycle (%) [70]
Chassis Fan Point2 Temperature [45]
Chassis Fan Point2 Duty Cycle (%) [40]
Chassis Fan Point1 Temperature [20]
Chassis Fan Point1 Duty Cycle (%) [20]
AIO Pump Q-Fan Control [Auto Detect]
AIO Pump Profile [Standard]
AIO Pump Q-Fan Source [CPU]
AIO Pump Step Up [Level 0]
AIO Pump Step Down [Level 0]
AIO Pump Speed Low Limit [Ignore]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
Secure Boot Mode [Standard]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
BIOS Image Rollback Support [Enabled]
Publish HII Resources [Disabled]
Flexkey [DirectKey]
Setup Animator [Disabled]
Profile Name []
Save to Profile [1]
DIMM Slot Number [DIMM_A]
Download & Install ARMOURY CRATE app [Disabled]
Download & Install MyASUS service & app [Disabled]
Special Display Features [Disabled]
D3Cold Support [Disabled]
Discrete GPU _DSM Function A [Disabled]
Discrete GPU _DSM Function B [Disabled]
NVIDIA DGPU Power Enable [Disabled]
Non-Eval Discrete GPU Support [Enabled]
Discrete GPU HPD Circuitry [OR Circuitry]
Discrete GPU's USB Port [Keep Default Setting]
Discrete GPU's SSID/SVID [Keep Default Setting]
Discrete GPU BOMACO Support [Disabled]
Thunderbolt / USB4 Support [Enabled]
Thunderbolt / USB4 Security Level [No Security]
Thunderbolt / USB4 MMIO Resource [Full Size]
Thunderbolt / USB4 Wake Up Command [GO2SX Command]
Processor Aggregator Device [Enabled]
Core Count Control [Enabled]
SMT Control [Auto]
RX DFE Taps [Auto]
TX DFE Taps [Auto]
DDR5 Nitro Mode [Auto]
VDDG Voltage Control [Auto]
SoC/Uncore OC Mode [Auto]
SoC Voltage [0]
VDD Misc Control [Auto]
LCLK Frequency Control [Auto]
VDDIO Ctrl [Auto]
Enable Platform PMIC Control [Auto]
VPP Ctrl [Auto]
Managed to do 7600, speeds are pretty much same as 6000 1:1 with the memory controller... :rolleyes:
Thanks TTL !
Been playing Star Citizen most of the afternoon and averaging 85% ram usage, no issues what so ever (apart from the bugs in the game :) ).
Lets hope AMD can squeeze more memory performance from this platform with the next gen ZEN 5 !
So after 3 days of fine tuning, I finally settled for 7800 61ns latency and 96Gbs R/W
Good Job that Man! Kudos
Notice you're running a Gene, is that because you're a mem enthusiast and only want 2 slots or a SFF fan?
Reason for the Gene is because I have an O11D mini.
It was the Gene or the X670E-I as I need USB 4.0 / 40Gbps connectivity (for 10Gig thunderbolt network card) and no other boards proposed this.
32Gb is enough ram for the moment and I can always upgrade to 48Gb if needed (some nice kits of 2x24 are being release too: https://v-color.net/products/manta-xprismrgb-48gb-dual-ddr5-ocmemory?variant=43360428359847 )
