Jamesey162
Basically, for some reason when I set my screen resolution to 1080p when using HDMI it stretches out beyond the screen and what is displayed is only 1680x1050 of the 1920x1080 image (example) but If I use a VGA cable I can set my resolution to 1080p without this happening. I've tried both the DVI and the mHDMI port on my card but it still happens.
The monitor I'm using (really, it's a TV) is an LG 22ls4d which has it's maximum resolution listed at 1680x1050 but why is it then that I can get 1080p over VGA?
Also, why is it people don't recommend you use VGA? (for example) I can't see a difference in the image quality vs HDMI.
Thanks
Thanks
