GeForce GTX 660 Ti and Max Payne 3 Settings
cmamath13
I just installed my new GeForce GTX 660 Ti video card and I am playing various games to see how it runs. Most of my games don't really push it (L4D2, DeadSpace2, Dirt3). I have Max Payne 3 and was wondering what settings would work optimally for my system. I want high frame rate but nice quality too. I found this web site helpful:
http://www.geforce.com/optimize/guides/max-payne-3-tweak-guide#1
Currently, I am running my system using these settings:
http://www.geforce.com/Active/en_US...payne-3-tweak-guide/0_1_Graphics_Settings.png
EXCEPT, my resolution is 1920x1080.
Any recommendations on settings would be appreciated. Particularly if you have a GeForce GTX 660 Ti!
Also, do you have any suggestions on the Nvidia control panel settings. I think the default is "Use the advanced 3D image settings".
Have you tried any of it yourself yet?
Id say max most things and justturn the AA down a few notches. Then test with FRAPS to see what kind of FPS youre getting.
Does that work with any game?
Should do, there is a game comparability list in the link I think.
No loss in IQ without AA , how does that work ?!
I don't know the technical details but I know it works because I use it :D
SMAA is a AA but instead of the graphics card doing the work the program or how ever you describe it does the work, hence the boost in FPS.
Here is a vid that explains it in a bit more detail.
http://www.youtube.com/watch?v=XXBnA8Xbka4
Wow! Thanks for the info! I appreciate it. I may give that SweetFX a whirl. First, I want mess with built in settings.
By the way, I was unable to view last video in this post. I think it's because I am here in USA.
