yes , around that number1300 euros?
You had a 6990 to power a single 1680x1050 screen?
Ok well you should be able to get
Cpu - i5 3570k
Motherboard - MSI Z77A GD55
Ram - Corsair Vengeance 8gb 1600mhz
SSD - 128gb Crucial M4
Hard Drive - 1tb Western Digital Caviar Green
Power Supply - Corsair AX650
Graphics Card - Nvidia GTX 670
Case - Personal Choice
Why wouldn't I be sure? It is a high end board, easily capable of allowing 4.5ghz
I prefer Gigabyte, and it will work fine with ram above 1333mhz, and the Corsair ram is blue to? I think it would look better tbh
Use it for games and os, and yes it is certainly worth it
BTW, Maximus V Gene is more expensive than the MSI GD65 or MPower, totally not worth it.
Was thinking the same !
okay say here's the setup im going to get..
changed the mobo.. ( own preference )
so you're realy sure im going to make it with a 650PSU ?
i was thinking to get a higher psu...
so i dont need to change that when i get an another GTX670?
SSD : OCZ Agility 3 120GB 2.5" SATA3
RAM :G.Skill Sniper 8GB(2x4GB) DDR3 1600MHz CL9
CPU :Intel Core i5-3570K, 3.40GHz, 6MB, HD4000, S1155
MOBO : Asus Sabertooth S1155 Z77 4xDDR3 ATX
CPU COOLER : CoolerMaster Hyper 212 Evo
GPU :Gigabyte GeForce GTX 670, 2048MB, OC
HDD :Seagate Barracuda 7200 2TB 7200rpm 64MB SATA3
PSU : 650W ( enough? )
CASE : CoolerMaster CM 690 II Advanced,white&black edition
I was going for the Sabertooth aswell, check out the MSI Z77 MPower, you'll love it! Same price as Sabertooth, much batter in terms of overclocking, reliability and durability.
for a case, i am partial to the fractal design arc midi. toms review.
great air-cooling case and excellent water-cooling capabilities. and a price
point that is easy on the wallet..
airdeano
