You all figure this will be a good rig for playing most current games (and past games?)
The specs of the NEW build:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-3770 3.4GHz Quad-Core Processor ($259.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.90 @ NCIX US)
Motherboard: Gigabyte GA-Z77X-UD5H-WB ATX LGA1155 Motherboard ($214.99 @ eCost)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($46.99 @ Newegg)
Hard Drive: OCZ Agility 3 120GB 2.5" Solid State Disk ($99.99 @ NCIX US)
Hard Drive: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($109.99 @ NCIX US)
Video Card: Diamond Radeon HD 7970 3GB Video Card ($449.99 @ Newegg)
Case: Cooler Master HAF 932 Advanced ATX Full Tower Case ($129.99 @ Newegg)
Power Supply: SeaSonic 750W ATX12V / EPS12V Power Supply ($159.99 @ Newegg)
Optical Drive: Lite-On iHAS224-06 DVD/CD Writer ($19.99 @ Newegg)
--------- Will buy these two later, or at lest the monitor-------------
Monitor: Samsung P2770FH 27.0" Monitor ($294.98 @ NCIX US)
Keyboard: Microsoft SIDEWINDER X4 Wired Gaming Keyboard ($44.04 @ Amazon)
Total: $1907.82
(Prices include shipping and discounts when available.)
(Generated by PCPartPicker 2012-05-16 22:02 EDT-0400)
Current specs:
And what I wanted in a new system:
Hardware
Software
Gaming Software:
Will use steam:
Will use CD/DVD's of the games I have:
Other Thoughts
Monitor Thoughts:
- Budget - Within about $1600 (American)
- Resolution - At first 1680 x 1050 - Eventually HD (and a dual monitor setup)
- Games / Settings Desired: Everything from DOS era on. Most should probably be high settings (if not ultra)
- Country - USA
- Parts that can be reused: Not that I can think of (see current specs as to why)
- Buying Parts: Before the end of the year, hopefully before fall or end of summer
- Will NOT prebuilt (like my last)
Total: $1907.82
Current specs:
- CPU: CPU Type DualCore AMD Athlon 64 X2, 2000 MHz (10 x 200) 3800+
- Motherboard: Motherboard Name Asus A8N-BR (Pyrite) (1 PCI, 2 DDR2 DIMM, Audio, Video, LAN, IEEE-1394)
- Memory: System Memory 3008 MB (DDR2 SDRAM)
- Hard Drive: Disk Drive SAMSUNG SP2504C SCSI Disk Device (250 GB, 7200 RPM, SATA-II) [can I really use SATA speeds?]
- Video Card (GPU): Video Adapter NVIDIA GeForce 6150 LE (128 MB)
- Case: HP Pavilion Slimline (7700n)
- Optical Drive: Optical Drive HL-DT-ST DVDRRW GSA-H20L ATA Device (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
- Operating System: Windows 7 Home Premium 32 Bit
Hardware
- USB 2.0 speeds that are minimum of 30 MB a second
- USB 3.0 speeds that are at lest 300+ MB/s [I will get / use an SSD]
- Firewire (and or eSata port) --- because I have a external hardrive that has both along with USB
- At lest a solid terabyte (1.5 TB)
- Supports VGA & DVI (@ first) - eventually HD for the new monitor
- Multi card reader (although I mainly need SD and Memory Pro Stick Duo)
- Able to use a PS3 controller AND A XBOX 360 controller (yes I know 360 is native support . . .)
- I would like a quad core.
Software
- Windows 7 Ultimate (64 bit) (Main OS) -- Mostly for languages
- May first run Windows 7 Home Premium 64 bit - as I have both 32/64 bit discs now)
- Windows XP - May run through virtual machine
- Folding @home - (alth ough I use my PS3 for that when I'm not using it)
Gaming Software:
Will use steam:
- Elder Scrolls (Morrowind -> Skyrim)
- Portal 1 & 2
- Batman Arkham (Asylum/City)
- Sonic Generations
- Quake (all)
- Doom (all)
- Wolfenstein (all)
- Commander keen (all)
- Bioshock (1/2) (perhaps infinite)
- L.A. Noire
- Bejeweled (all)
- Peggle (all)
- Various COD's
- anything else that interests me
- Warcraft 2 - Tides of Darkness & Beyond the Dark Portal
- Warcraft 3 - Reign of Chaos & Frozen Throne
- Diablo 1 - 3 (when it comes out)
- The Sims 1 - And all expansions
- The Sims 2 (probably)
- Simcity 4000 & Rushhour
- May use emulation (to run up to the PS2/Wii)
Other Thoughts
- Eventually a dual monitor setup (and one be HD resolution)
- I will wait for some parts (hard drives, GPU, etc) to drop in price.
- Will wait for IvyBridge. . . .
- I WANT UEFI, NOT regular old BIOS (that this slimline has
- May eventually like a dual GPU (crossfire?)
Monitor Thoughts:
- First and foremost: HD
- Supports: HDMI, DVI, Displayport (if the motherboard of the computer does)
- Within 1 - 2 MS response time
- Screen size - 25 to about 27 inches (this desk doesn't really have a lot of room)
- Also is widescreen.
