Gaming Rig Finished...
BadImpact
Quad core gaming rig finished
Intel core i5 760 @3.8Ghz
MSI P55-GD65 Motherboard
4GB Corsair XMS3 1600MHZ DDR3 Kit
XFX Radeon HD 5850 1GB
Corsair A70 CPU cooler
Corsair HX750w Modular Power Supply
LG DVD Burner
Coolermaster HAF 932 Advanced Case with USB3
Here are some pics of the system
yeah! I had a thermaltake M9 case and i thought that was big. Then I bought this and it was way bigger than i thought it would be! beware if you have a Mid tower and looking for a full tower, you better see if it will fit where ever you are planning to put it!
nice rig
Thanks! Next step is to get rid of the IDE drive and replace with a sata one because that ribbon cable looks awful. Thanks for the good feedback guys"
Might be cheaper to get a round IDE cable with your next order instead.
I mean I've only just noticed that you even have the ribbon cable in there.
Is it IDE for a HDD or an ODD? If it's for an optical drive, I'll prolly go for the round IDE cable if there's no real need to upgrade the capabilities of ODD.
