Hello Community,
First of all, I would like to say “HI” to all of you and praise this community. Very well organized and fun to read. Recently discovered this forum after starting to do research for a new pc.
I must say I’m very overwhelmed by the advancements that took place in the last 3-4 years that I wasn’t active in gaming and it is very hard for me to jump in again. PCI-E 3.0, native USB 3.0 and Ivy B, so complicated today! Therefore, I would appreciate it, if you guys could help me a little building my new gaming machine.
I will be using the computer for heavy gaming and video editing. I’m OC friendly
I’m very unfamiliar with watercooling but I want to try it. From what I’ve read, buying a big case and part separately should bring good results. I would prefer an Intel cpu and the gpu should be Nvidia. I would love to try SSD(s). Is it possible to have a system ready to run Ivy (i.e. motherboard, ram, etc)?
My budget is 3500$ but not all of it has to be spent!
What parts do you recommend?
Should I buy the GPUs ready with water cooling block? Is SLI recommended?
How about SSDs? Which ones are current and reliable? Is raid 0 overkill?
What kind of Ram should I get and at what level of mhz?
Also, there are way too many cases for me to see which would be ideal for water cooling and radiators with lots of room to play around to upgrade. Which ones would you recommend?
What WC parts should I get to have very good cooling but not too much noise? How many radiators would I need to cool cpu, gpu (2), northbridge? Is there a good unit to track flow, temperatures and other related things which also looks cool and is easy to use?
Thanks and have a great day!
