B barginbin New member Dec 1, 2007 #1 hi i am after a gaming headset and i see there loads out there i was just wondering what ones you find best etc I like the idea of the force feedback headphones has anyone used them? My budget is £40 delivered max. Thanks for any help/advice you can offer.
T !TIMMY! New member Dec 1, 2007 #2 Personally id get these. I have the older version and i love them. A bit above ur budget, but with cheap delivery will prob cost u around £45.
H Ham New member Dec 2, 2007 #4 I use zalman 5.1s. They're good enough. Meds are better. If your not fussed on 5.1 the Senhisier (cant spell that) PC151 or w/e the latest one is would do you proud.
B barginbin New member Dec 2, 2007 #5 name='Brooksie' said: Ooo Timmy, they look nice, might need to buy myself a pair!! Click to expand... Me to they look pretty dam good! Thanks for all your help
B barginbin New member Dec 2, 2007 #6 Only thing with them are i dont have 5.1 ss card but i can just plug in the in out jack and one into the usb cant i? Im going to get 5.1 ss on my new rig
T !TIMMY! New member Dec 2, 2007 #7 Yeah that shud be fine, I love 5.1 in games. makes games so imersing.
L llwyd New member Dec 2, 2007 #8 For pure gaming functionality go for the Medusas For comfort, build and sound quality, get something like some Sennheiser or Technics DJ / music headphones, with a decent source they will put nearly anything else to shame.
M mrapoc New member Dec 3, 2007 #9 My Medusas stopped vibrating after one lan party (about 8 days after i got them)... The volume box came apart after 3 months and died after 4-5 months bad build quality and HATE x fi sound cards Getting Sennheiser HD555 for xmas - no more 5.1 sets for me, all crap that x fi thing can produce 5.1 anyway (virtual) cssmd or something
