Frosty build 001 2013
Fr0sty
I guess a little introduction here is in order, and whats the plan.
Well Ive been building PCs from when I was 8 years young, and would builds the PC for my father and his friends etc; it just interested me; and now 20 years, and 74 builds later; my very first Build Log.
The main reason about doing this, is to one; get used to keeping record of the steps I take, two; self advertisement (not that I would find any here, as im in Australia) and 3, well because this is gonna be the bee's knee's; its gonna take me a bit of time, and I want to keep the client happy by telling him what im upto.
Simple... I hope.
Now to go along the Parts picked/chosen (taken 2 weeks of back and fwd between the client to keep the parts in order)
Going for a White/Black/Blue Sci-Fi look/feel. And will be used to play his long range collection of steam games; (638 last count, not including DLCs)
Main Hardware:
Motherboard = ASRock X79 Extreme9 (Chose this motherboard for the number of ports on it, as in future the client may want to add more HDDs; and ive worked with the bios before for OCing) (Oh, and I may have the waterblock with me as well :) )
CPU = i7 3930k (Because it less then the 3970X by about $400, and for gaming, you dont need that sort of power.
RAM = G.Skill Ripshaws F3 1600 (32GB )(Sure he doesnt need 32GB, shoot only 8GB would do really, but when you got the spare cash, and want the thing to look even on a 2011 chip board, 4x8 sticks look so god blasted sexy, even more so when water cooled)
GPU = ASUS 7950 TOP 3GB (Now this was more of a "I have two spare 79x0's water blocks"; and this would let the user to use the last of my "active DP cables"; sure I could of gone for a single 690 (aka 2 GPUs on 1 PCB )but this just got rid of some spare parts, and makes it look like there's two floors inside the case, still have to buy the back plates but)
HDD = Intel 520 240GBSSD (Ahh just for the reliability and for the warranty factor)
HDD 2 = WD Blacks 2TB (3 of them, because steam really is his golden apple, and that tree is getting a little cold; also one of the fastest reliable HDDs out, with a huge 5year warranty right off the get-go)
PSU = Corsair AX1200 Gold (Bang for buck, and had it spare; all I did to it, was paint the sucker white on the outside, while keeping the corsair logo on it)
Optical Drive = Silverstone BR Burner Slim (Its slim and sexy looking, also is needed for side mounting)
Case = Thermaltake Level 10 GT Snow (yes; a little bit of cutting will need to be done to it XD)
Cooling Hardware:
Reservoir = Bitspower Z-Multi 250 (This will be 1/4 sticking outside the case when the doors are closed, to give it that extra WOW factor (Not World Of Warcraft))
Pump = Koolance PMP500 (Yes this thing can be used on a med size watertank, but ill be setting it to its lowest setting to keep it hush hush, as much as possible.
Radiator 1 = XSPC 240 Crossflow (As much cutting as I will be doing to the case, I want to try and keep it to a min, and this is the largest size without cutting)
Radiator 2 = XSPC 240 (Now this will force me to cut the case, infact, this will be going where the drive bays are going togo; if you look at that slim Optical Drive I will be putting it on its side, next to the radiator)
Fittings = Bitspower Multi-link; and some compression fittings (If you see the tubing im going tobe using, you will understand)
Tubing = 1/2" Copper pipes, that are nickel plated. (Will be sanding and polishing this up for more WOW factor; but will maybe use normal or white tubes in unseen areas.
Waterblock CPU = XSPC Raystorm
Waterblock GPU = HeatKIller Nickel plated
Waterblock MoBo = MIPS Extream 9 Nickel Plated (Very hard to find, as they primaraly make the X11 version now)
Well lets see what I get done in 7days; ill probs just order the parts as I go along that I havnt already; as the client isnt able to pay me all the costs at once. but his trying to sell his jeep for it XD.
I did find that sourcing the pipes was a little hard at first, as REECE wasnt too sure on the exact size of their pipes (Aus = 12.07mm OD); but after a little bit of sanding that was needed, and polish, they fit snug into the multi links :D
Cheers Guys and Girls.
P.S. Would love it, if corsair did a watercooled PSU.. with a clear plate... how sexy.
Okay; well its been a week from the last viewing of this, and so after the guy gave me 1/3rd of the payment I went and got started on getting the parts.
Some parts I was lucky on, as I just have them as spare parts, and others, well, I had to get them Direct from the supplier.
Well here is the first of many packages that will be sent to me, via my work.
To be honest, after I ordered the parts on wednesday, I totally forgot what I did order so even I was pleasantly surprised when I got my Stanly knife (or box cutter to you brits) and hacked away like a cave man on his first date...
And so, here is what I got...
Please note on the above picture, the AX1200 and the 240 radiator I already had, the fans are there to remind me of how much REAL room I need to fit the sucker XD.
And so I got my tools all layed out, so I know what ill be needing, and so they arnt just all over the house.
Wait, whats that.. an anti static strap... hold on lets fix that.
And I guess there is one tool we all need to use, sadly I could only show one, as the other was holding the camera.
Heres what 40 connectors from bitspower look like, flown all the way from Thailand; keep in note guys, you can pay via paypal, but they rather you pay direct so they get the full $$$ and not have to pay paypal for transferring the money, and if you do that, you will need to confirm with your bank the transaction.
Wait this looks like 39... if you look at the box, you will see its slightly raised, thats because once I moved the box, the last one was hiding under the box
Now for the case, and for the work to begin.
After inspecting it for its clean looks I know what I was gonna do to it, if you do want an unboxing of this case, theres plenty all over the net (youtube)
Get the case open, and check out what they think I may need.. pfft; all that got put back into the box; and that Air direction thing on the door, just had to go, what a piece of plastic. As I took the screws off the fan thing, it all came apart.
I was worried about clean looks and getting power to light up the door, till closer inspection, showed they had found a nice novel way of getting power to the fan already. so I can de-solder the current wire, and use LEDs
Well, I got the screw driver out, and took out ALL the screws I could, after all, a modded case isnt really modded till you strip it down and get a sexy music to play in the background (ohhh, if only I had some red globs to set the mood)
Well, as sexy as it looked being this naked, it seemed to need a little shaving in the bush area, or in this case, the HDD racks and the 5 1/4 racks needed to go... So one drill later and a bit of fun later.
Looking at the drill after, I just couldnt help but laugh, as I wasnt paying attention to the bit till the end, I was wondering why I could drill much further in... who needs sticky tape to mark how far, just use the pot-rivets to show you
Well; I cant really update this anymore this weekend, as I have to go to bunnings, and get some more 2mm ally plates, as im gonna need more then I thought, and I may have to make a whole new side door :( (Blasted plastic door.
Catch you guys in 7more days.
Sorry I have nothing to update this weekend; as ive come down with what ill call the $40 cold :(
Was gonna go out tonight, paid for tickets and all... cant go now, blasted cold.
Hi FrOsty,
I hope you have a quick recovery from your cold ( colds suck ).
It never fails , always get one when you've made plans.
I'll be patiently waiting for more updates for this very cool build, get well soon.
Well I do have some news, I have done some work, just not enoguh to warrent it on todays post, so ill wait till nxt sat.
