I'm a relative watercooling newb, I've done one build in a CM 690 II (pull 240 top, push/pull 240 bottom) which basically mirrored exactly the configuration TTL described for that case in his video.
I'm trying to plan for my X99 build and most of the cases I'm looking at (760T, 540 Air, 450D) are configured to support a rad on top and a rad in front, but not really a rad at the bottom (without modding). This presents me with a conundrum, should I intake through the front rad or use the front as an exhaust?
If I use the front as an exhaust, I'm worried I might not have enough air coming in (flip the rear 140 exhaust?), but if I use it as an intake, I'm worried about heating the non-actively cooled components in the case with warmer air after coming through the rad.
I've read a lot of post comments online saying to just use the front as an intake, but they seem to ignore or not mention the side effect of warming other components in the case.
There seem to be a lot of cases that set up for this config (top & front rads), have there been any reviews or tests regarding the temperature deltas in the case? Anybody had success putting a filter on the rear 140 and using it as an intake?
Thanks for any help or suggestions.
