bwooly1001
Hi guys thanks for taking a moment to look into this for me.
I'm wanting to do a clean black and white build with blue highlights (fans and cpu cooler) so have put something together on scan that I want to build.
I am not interested in overclocking this at all but am needing liquid cooling as I live in flats and it gets to a toasty 30c+ when other flats have their heating on.
I want the m2 for speed while editing and utilizing capture and streaming software.
This is what I have put together in scan - http://www.scan.co.uk/savedbasket/79478524-8bc7-4375-a8cd-9323fc49d008
I am going to be re-painting/colouring some parts as I want a unique custom build.
I have filled this out so anybody wanting some extra info can have it.
• Where are you located? UK
• What is your budget? 1350
• Will you need a monitor, keyboard, and/or mouse included in that budget? nope
• Shall you be requiring an OS? windows 10 64bit
• What will you be using this rig for? gaming,streaming,recording and editing
• If gaming, what resolution will you be playing at? 1440p
• Will you be overclocking? no
• Do you need a full build or will you be reusing some old parts? full from scratch
Is there anything I have missed or should swap out?
thanks in advance guys
