Would I be better off just running the SMP and forget about GPU folding on my main rig. I7-2600K, 8 GB Mushkin Blackline Ridgeback, R6950 2GB Twin Frozr II?
The PPD for this card is only around 2000 PPD and it seems to slow down the SMP client.
Yeh mate, run SMP on its own and if you see a positive difference, just fold with the CPU
Thanks, I just picked up a GTX 460 on ebay to go into my folding rig.
It's addictive isn't it![]()
Thats the spirit!!!! Hooked already.
Out of intrest, what version 460 is it? The 1gb or 768mb?
Just as a FYI for anyone reading, While the 768mb version is faster at gaming because of its extra ROPS and memory buss size, they are both the same speed at folding. So if you get a 460 off ebay just for folding and you have a choise and there are a decent different in price, take the cheapest.
A few yeats ago I had the chance to fold on a 8600GT along side a 8800GT. I seem to remember it getting about 1500 PPD but I can't be certain.
Oh and SEBAR. When folding on the nvidia cards, if your computer can take a bit of extra heat, its worth folding -advmethods on the GPUs. Not only will you get slightly better PPD on the GPUs but they take less away from the CPU to than non -advmethods.
Yes it is. I hoke up early this morning to check my status.![]()
it is an EVGA GTX 460 768mb. grabbed it for $110 (U.S. Dollars). I am going to use the 8600GT until the GTX 460 arrives.
She's my second backup............my first is at present undergoing a rebuild and that will be more than up to the job................will let you know when she's finished![]()
mArTyN
It's not really worth folding the Pentium 4, you would probably only get a couple of hundred points per day out of that.
The 9600 might be ok for a couple of thousand. If you run MSI afterburner, downclock the core but overclock the shaders you should get some extra points while using less power.
Out of intrest. Is that the only rig to fold on or an extra on hidded away?
