Fitting A Radiator
Ollii
Hey, Just coming round to fit my 360mm radiator in my 700D and it comes with 12 fan screws but how an earth do I actually attach it to the case safely? Do you have to buy some other screws or do some good ones come with the case? Could someone please give me some advice on this? Thanks.
Depends on your rad, but you have to buy your own normally. Unless the screws are 30mm long then they are for the rad aswell.
Ok thanks, My rad is a "Thermochill TA Series 360mm Triple Radiator" so could someone give me some suggestions on what screws to buy? and where to get them from (I live in the UK).
have a look at WCUK,specialtech
Hey, I've had a look at the websites but I cant find any information about screws for fitting them to your case, unless I'm just being stupid
so I'm still not really sure on what I'm looking for, any advice ?
Thanks
