advancedkill
Im putting together a new pc rig. It has an 80 watt peltier cooling the gpu (9800xt which i will overclock) and that is in turn water-cooled. I was going to use a triple fan radiator to cool the peltier (i know its a bit much but i may add in another part to the watercooling loop later). Then i found out that a triple fan radiator and water-cooling system took up a lot of room. Now i have to find a case that will accomodate all of the stuff.
I saw in an issue of custompc (great mag) a pc with a swiftech radbox holding up a triple fan radiator outside the case (i think it was made by scan). Do you think that i could do something like that, and then mod the top of the case to fit anothr triple in the future?
NOW THIS IS WHERE YOU COME IN (YES, YOU!) Could anyone please find me a case that will acomodate all of this kit (i dont want anything bigger than a coolermaster cm stacker, as ive already got 1 - and i dont want another 1)
Cheers!
Cheers!
