Hi everyone.
Been watching a lot of reviews about watercooling on youtube, and have decided to build my first setup.
i could do with just some general advise on a few things im unsure on.
My Setup is as follows,
Cpu: i7 2600k @4.5ghz
Cooler: Currently using Corsair H50
Case: Coolermaster Nvidia HAF-X
Gpu: Evga Gtx 570 (Soon to be Gtx 670 Ftw)
Motherboard: Gigabyte - Z68X-UD3H-B3
Fans: 3x 200mm 1x 230mm
Psu: Coolermaster 850watt
SSD x2: 120gb Agility 3, 120gb kingston hyperx
HDD: 3x 1tb Drives
Memory: 4x4gb Corsair Vengeance @ 1600mhz
Now what im considering is the following
XSPC Rasa 750 RS360 WaterCooling Kit
Mayhems X1 Premix Fluid for Water Cooling 1 Litre : Clear (x2)
Mayhems Dye 10ml Dropper Bottle : UV Yellow / Green
Coolermaster 120 x 120 x 25mm SickleFlow Green LED Case Fan (x6)
Phobya 6-32 UNC x 35mm Cross Head Screw 4 Pack (x3 Packs for extra fans)
Now this will only be for cooling my cpu only at the moment, my current temps with my H50 are around 33-37c Idle, and 65-70c running prime 95, ambient temps of around 20c vcore 1.29v Stable.
Im stuck really now on which fans to choose, im currently using 2x sickleflow with the h50, but is there a better fan for this setup.
Also i normally use artic silver 5 thermal paste, but i spotted this EK-TIM Indigo Xtreme, and watched a few reviews, but im still unsure if its worth the extra money, and by the looks of the videos on youtube, the burning in technique required after its applied looks risky.
Id appreciate any advise, as im planning on ordering it Friday for Saturday delivery, from specialtech, so any tips or changes would be appreciated.
HDD: 3x 1tb Drives
