M mickey New member Mar 8, 2012 #1 hey guys want to know if the xspc rasa 240 will be good enough for..... intel core i7 2600k NZXT switch 810 i am jus cooling the cpu alone.
M mickey New member Mar 8, 2012 #3 i might do the push pull config witll the RX240 fit the case?? its just the cpu im cooling really so i dont think a tripple rad will make a difference.
S_I_N New member Mar 8, 2012 #4 the switch 810 is designed to handle a 360 or 420 mm rad in the roof 60mm thick in push pull with no sweat ur rx240 kit should be fine mate.
