purplemonkey
Hi guys
First overclock since building my first rig way back about 3 years ago where I successfully managed to OC a Q6600 to 3.4ghz on air.
Just built my latest rig with the following specs...
I7 2600k
P8z68-pro Asus
16gb Vengeance LP
Msi frozr gtx570 oc
Corsair 750 modular enthusiast series
Nzxt Phantom
Noctua Dh-14 cooler
I am looking to overclock to 4.8ghz
Having read a few guides the settings you seem to change in the bios appear to have simplified considerably. I have worked out that I need to adjust the following.
Ai Overclock Tuner - set to manual
Bclk-Peg frequency -set to 100
Memory frequency - set to auto or rated speed
Dram timings - set to manufacturers ratings
Drama command mode - 1t
Load line calibration - Ultra high
CPU voltage - set to manual
CPU voltage - set as desired (max 1.4/1.5)
Dram voltage - set to manufacturers specification
Vccio voltage - 1.0v
Vccsa voltage - 0.9v
Hyper threading - off or on
Is there anything else I have missed before I begin?
I remember overclocking the q6600 there were a lot more features to disable like
CPU spread spectrum
Nb and sb voltage settings
Pci spread spectrum
C1e support
CPU tm function
Have I missed something one these newer machines that I need to enable or disable as so far I seem to need to play around with a lot less in the bios ??????????????????????????????
Many thanks for taking the time to help out!!!!
I7 2600k
P8z68-pro Asus
16gb Vengeance LP
Msi frozr gtx570 oc
Nzxt Phantom
Noctua Dh-14 cooler
CPU spread spectrum
Pci spread spectrum
C1e support
CPU tm function
