xuuk3r
hello guys!
I've been considering a fully custom loop for quite some time now and the main thing holding me back is that i've never done one before. But since i really want to try one i'd better be getting some expert advice from you guys cause i'd want to get it right from the first time
This is what i would want it to look like eventually
My Rig:
Case: NZXT H440
MB: Asus Maximus VII Hero
CPU: Intel I5 4690K
GPU: Asus 970 GTX Strix
PSU: Corsair 650RM
So this is what i came up with after doing some research.
CPU block: EK Supremacy EVO
GPU block: EK 970 GTX Strix Nickel + backplate
Pump + Res: EK BAY DCP 2.2 Combo unit
Rad: Swiftech MCR320 360 radiator
So far the easy part.. Since i'm Belgian and we use milimeters here that requires a lot of checking and rechecking lol
Tubing: Acrylic 12/10mm = 3/8" ID
Fittings: EK HDC fitting 12mm ~ 1/2"??
I also want to add a splitter for draining so is this the correct way?
Bitspower G1/4 T-Rotary adapter
Bitspower G1/4 to G1/4 (2xOD) link
Bitspower valve
Bitspower G1/4 Stop fitting
So i would just need to insert the T-rotary adapter in my pump/res since that's going to be at the lowest point. is that correct?
The things i'm not sure about:
Is my 650watts going to be enough?
Best ways to bend the acrylic tubing (not having a heatgun)
Is 2L of coolant enough?
and is the pump strong enough for this loop? Don't know shit about pumps lol
Thanks in advance guys!
My Rig:
Case: NZXT H440
CPU: Intel I5 4690K
PSU: Corsair 650RM
Bitspower valve
