First Build 1.1k Improve My Spec?
Yeti
Hey all! another noob in need of guidance lol! after trolling through various forums, video reviews etc, I've come up with a list of components. This will be my first pc build, I've done some research though so I'm not jumping in too blind. Anyways, I've posted the specs below.. Advice, recommendations etc would be appreciated.
Cheers. :beerchug:
CASE:
NZXT Phantom 410 Gunmetal
CPU: Intel Core i5-3570K
CPU COOLER: Noctua NH-D14
MOTHERBOARD: MSI Z77A-G45
SSD: Crucial m4 128gb
GPU: Gigabyte WindForce GeForce GTX 670
RAM: 8gb (4x2) Corsair Vengeance Low Profile 1600MHz
PSU: Corsair AX Gold 650w (Modular)
OS: Windows 7 (64bit)
OPTICAL: LG GH24NS95 (cheapo)
FANS: 3x140mm NZXT FZ
TOTAL: £1060 (including p&p) -using 2 sites
BUDGET: £1100
Dont pay more than £50 for windows 8, all you get is a sticker if you get the expensive one :p Also how much ram are planning on getting?
Get a Silverstone Strider instead of the HX, no reason not to go fully modular at that budget dude.
looks good, maybe a better corsair psu you could try and im sure you could squeeze in 16gb ram if you wanted, there's always somewhere offering 16gb on offer as cheap as most 8gb
windows 8 :/
typo.:o
Thanks for all the replies.
ok so this is the updated spec:
CASE:
PSU: Corsair AX Gold 650w (Fully Modular)
(switched psu to AX, graphics card (found cheaper on deal)
However there is one thing bugging me about the build, theoretically i would be spending £120 on the nzxt mid tower / extra fans (no included dust filters & psu cooler would be tight -I've heard) this is starting to put me off since i could get full tower (which i assume is better long term) for the same £££ if not a little more.. which would still be in budget. If i got rid of the case/fans i would be left with £160. Any suggestions on what i should do?
Cheers.
