sosolidshoe
OK, so I have my major components all picked out, I have a budget in place, but I still can't decide on a case.
I want to create a low-noise positive-pressure environment, and I am willing to get spendy if I have to(although I'd obviously prefer not to
). I can't stand viewing panels in the side of my cases, since I'm a function guy and I build Frankenrigs with no regard for interior aesthetics. The case also needs to be able to support an H100i set up as an exhaust, and ideally with room for push-pull.
What's most annoying me is that I swear there used to be cases which were just plain, black, Monolith-esque affairs with loads of front intake mounting points and a nice solid side panel designed for front-to-back airflow, but everything I can find now is either horribly over-designed or uses up valuable front panel space on features I'll never use like hot-swappable drive bays. Are there any cases about at the moment which have 3x120mm front intakes(to which I can mount the round 140mm Noctuas), a 140mm rear exhaust, and space in the top for the H100i? Or would I get better noise-to-airflow performance with these multi-200mm setups?
Any advice is appreciated.
