Finally Complete
Dilzo999
Released a thread about this a week ago, didn't have my gfx card or CPU cooler but now everything is complete and I overclocked the snot out of it :).
CM Storm Trooper,
i5 3570K,
Gigabyte GTX 670,
Intel 330 120gb SSD,
WD Caviar Green 2tb HDD,
Sony Optiarc Optical bay,
ASUS P8Z77 V,
8gb Corsair ram,
Xigmatek Aegir CPU Cooler
Corsair AX650 PSU
Also would like to add thanks guys for the comments last time :D.
Turn the second fan on the cpu cooler round and hide that wire better.
Also the psu is the wrong way up :p
Looks good other than that though
Nice man, I'd just tidy up those fan cables a little bit, other than that she's a beauty. What OC did you get on the GPU and CPU?
It's all personal preference, there's no right or wrong way up. Just cause TTL says it HAS to be fan side up doesn't mean it's gospel. Some people like it that way.
please see my above post or this thread will be deleted
Doesn't let me edit for some strange reason there's no "Edit" button, just multi quote, quote and quick reply.
Yeah I got to 4.2 GHz in my i5 3570k with really good temps stays at 55C on prime95 and around 45 while I'm gaming. Also for my GPU I got it to +120 on core and +600 on mem so 1250/7200. Seems pretty decent but other people have gotten over 1300+ so I'm a bit disappointing but it's still a fast card :D.
Ok my specs are :CM Storm Trooper, i5 3570K, Gigabyte GTX 670, Intel 330 120gb SSD, WD Caviar Green 2tb HDD, Sony Optiarc Optical bay, ASUS P8Z77 V, 8gb Corsair ram, Xigmatek Aegir CPU Cooler and finally Corsair AX650 PSU. Thanks mod for adding it in :D.
Damn, what did you use to OC it? I have the same Gigabyte 670 OC and am using EVGA Precision X and i've only got +65 on the core for 1045. :/
I use MSI Afterburner, after I setted my OC just ran Unigen on highest settings and checked if it was stable hopefully you get a high overclock :D.
A little off topic, but i'll post it anyway as it's still related: for stress testing a GPU, I've found that running Unigine 'open and run' style is more demanding. I had a higher failure rate when I was going for my 'top' clock, and my temps are higher than when I max it out also.
I would but it was a piss take to install that 2nd fan I almost pulled my heatsink off the mobo lool.
Yup, I saw someone saying that if Unigine passes the benchmark then games will be stable 99% of the time.
