Hi all,
I have been planning on building my own water cooled PC for quite some time now. A while ago I put off a custom loop for the favour of a h100.
Since then I have witnessed the beauty of some users of this forums builds and i need to build my own. But now im looking for a new build and am not going to skimp out this time!
Below is a list of parts that i have chosen based on my budget and liking.
If anybody notices something I'm missing or wont work well together please chime in! Id appreciate all criticism and advise possible!
Parts List:
Case
NZXT Switch 810 Matte Black Special Edition £149.77
Motherboard
EVGA 151-IB-E699-KR Intel Z77 £268.52
CPU
Intel Core i5 3570K £177.80
GPU
2GB EVGA GTX 670 FTW x3 £1000ish
OR
2GB ASUS GTX 670 Direct CU II x3 (if anyone can persuade me to a different branded GPU that offers higher clocks or a higher bin ratio then ill happily change)
Memory
2x4GB Corsair DDR3 Vengeance Racing Red
1866mhz, CAS 9-10-9-27 £43.37 (offers low timings and they match my colour scheme
2x4GB Corsair DDR3 Vengeance Jet Black
Storage
Already own some SSD's and fast HDD's + and have plenty of NAS storage.
PSU
Corsair Professional Series Gold AX1200 £214.99
Corsair Sleeved Modular Cable Kit - Red £62.99
Water Cooling parts list:
Radiators
Alphacool NexXxoS UT60 Full Copper 360mm £69.00
Alphacool NexXxoS UT60 Full Copper 240mm £53.04 (offers a drain port)
CPU block
XSPC Raystorm £50.00 (spraying red)
GPU block
any that looks good and fits, preferably see-thru for liquid aesthetic x3 £300ish
Reservoir & Pump
KOOLANCE RP-452X2 REV 2 £110 with pumps!
(i love the look of this combo. Im planning on running a dual loop config with red pastel in one loop and ice white in the other. This bay offers a very cool look with the use of two colours. If anyone knows of a cheaper unit then please let me know!!)
Tubing
Masterkleer, 1/2" ID - 3/4" OD Hose, Clear £15
Mods and accessories
Corsair AF and SP fans
Monsoon black compression fittings
Mayhem's Light Red Pastel
Ice White Pastel
Mayhem's Red Dye
Red or white led's to replace raystorms blues. Red leds to "leak" out of top vents and maybe running along the bottom outside of the case but very dim.
White LED strip inside to make the red and white "pop" (taking advise from Tiny Tom)
All in all im looking to spend around £2500 which hopefully will include all bells and whistles!
Parts List:
Case
Motherboard
CPU
GPU
OR
Memory
Storage
PSU
Radiators
CPU block
GPU block
Reservoir & Pump
Tubing
Ice White Pastel
Mayhem's Red Dye
