I have a corsair AX modular power supply unit an a XSPC dual 5.25" bay reservoir pump
Instead of buying a separate power device to power the motor, would it be okay if I simply use an existing standard 4pin peripheral power cable (that connects to the standard 4pin molex of the pump) to start my watercooling process? I have disconnected all other power cables.
