RobCharles1981
Member
So my Graphics Card has now apprantly devloped a fault. A Few months back I sent it back to ebuyer hence issues with Heat and I asked if I can have a different card and they said no problem as they would be able to "credit" my account.
Well what did they do send the bloody card away to be repaired and I duly had the card back after a few weeks.
So far it's been working fine, but very recently in gaming the screen would go "black" and the "driver" would crash and then I had a bsod and now I have all nice colored blocks on my screen.
So it's more than obvious now to get it back to ebuyer to replace it. I went into my account to raise an rma and it said I "can't return it" so I shot them an enote to explain the case so all being well I should get this sorted!
Now in the meantime I will have to put up with on board Graphics. My motherboard is the Asus P8 Z77-V X and its a more or less "plug and play"
So install the VGA driver and off you go. And I'm having issues installing the driver.
It says " The Computer Does not meet the requirements for installing the software"
I deffo install the Windows 7 64 Bit Driver and nothings happening.
I tried unsintalling the Asus Drivers then plugging in the monitor I hget dsiplay no problem when I get to Post I get display then it just reboots for some strange reason....
Any ideas why?
Thanks
Rob
Any ideas why?
Thanks
Rob
