Currently using this radiator
http://www.scan.co.uk/products/xspc-rx360-black-high-performance-radiator
With 6 of these fans in push/pull
http://www.scan.co.uk/products/120mm-scythe-kaze-jyuni-1900rpm-slip-stream-fan-sy1225sl12sh
Now all the fans run at 12v and are quite loud, but I am looking at making my pc quieter when I change the case to the new Coolermaster Cosmos case.
I am thinking of getting some Silverstone Air Penetrator fans for push/pull but not to sure.
I have always been told that the CFM is the most important factor but, after seeing TTL's review of the Noctua fans I am not so sure now as to if that's the case or not.
I don't want to use the Noctua fans though as I don't like the colour of them.
Looking for some black fans that will be quiet but give almost the same result's as I am getting now.
My other option is to get the Silverstone TJ11 case and change my rad to the RX480 with a set of quiet fans instead.
Basically I have my cpu on it's own loop and I am looking to get 2 new graphic's card's over the next few months and have them on there own loops as well.
Would like some advice please
I want my pc to be quiet but offer good cooling.
