Dawelio
Active member
Hey guys,
So I've been looking at 3 fans and don't really know which one to get... for radiator use and as a front intake fan.
Silverstone AP121
Noctua NF-F12 PPC 2000PWM
Phobya NB-eLoop (Black)
Which one would you recommend is the best, for both rad use, intake fan and as being controlled through something like Corsair Link or other software?...
From what I understand the Noctua has a 4 pin connector, but what does it really do?... as I've seen the molex to 5/7/12v adapter having 3 pin connector, although one pin is missing.
Same on my motherboard fan headers... now, what I don't get is what this "PWM" is for really?... is it the 4th pin that makes it able to be controll the speed of the fan etc?...
And what is the really big difference between a 3 pin and a 4 pin?... as noctua's has 4 pin and Silverstone's uses 3 pin one.
I must be really dumb as I don't get the explanation of Google, so thought you guys could perhaps do a explanation in basic english for me?... as I'm Swedish
Thanks!
Silverstone AP121
Thanks!
