Hi im using a antec cooler and the fan that came with it is noisy i was wondering if i got a noctua NF P12 1300 and i got a akasa ( http://www.maplin.co.uk/ultra-quiet-120mm-case-fan-45439?c=froogle&u=45439&t=module ) fan pushing air into the radiator and the noctua exhausting it and used a fan 3 pin to 2x 3 pin and plugged this into the motherboard cpu header would this allow me to control both fans and would they both be able to run at 100%, or would there power he halved.
the pump is connected to a power fan header which is always running 100%
finally would the akasa and the noctua be enough to cool this radiator i tried it with just the akasa fan and the temps went up by around 1 degree which was surprising.
